05-01-2007, 01:03
CHE NE DITE DI QUESTO AMPLIFICATORE????
37,73 KB
LANZAR VIBE286 AMPLIFICATORE 2 CANALI 4000WATT
QUESTO FANTASTICO AMPLIFICATORE LANZAR 2 CANALI CLASSE AB E IN GRADO DI EROGARE BEN 4000 WATT. E PUO ESSERE UTILIZZATO IN MONO PER AMPLIFICARE UN SUBWOOFER O IN STEREO PER GLI ALTOPARLANTI. INOLTRE E IN GRADO DI SCENDERE FINO AD UNA IMPEDENZA DI 2 OHM. QUINDI E POSSIBILE COLLEGARE FINO A 4 ALTOPARLANTI. FANTASTICO AMPLIFICATORE DELLA FAMOSISSIMA LANZAR VIBE!!! AMPLIFICATORI TOP GAMMA LANZAR DI ALTISSIMA QUALITA ED ELEVATA POTENZA
CARATTERISTICHE TECNICHE:
2 x 1000W RMS at 4 OHMS 2 x 2000W MAX at 4 OHMS
1 x 4000W MAX at 4 OHMS Bridged 2 x 1650W at 2 OHMS RMS
Electronic Crossover Network
Bass Boost Circuit
2 Ohms Stereo Stable
Anti-Thump Turn-On
Illuminated Top Panel
Soft Turn On/Off
High & Low Level Inputs
Power & Protection LED Indicators
Advanced Protection Circuitry
Remote Control Bass Booster
THD: <0.04%
S/N Ratio: >90dB
Channel Separation: >65dB
Freq. Response: 15Hz~35kHz
Dimensions: 11.06''W x 2.24''H x 21''L
37,73 KB
Bass Boost Circuit
Anti-Thump Turn-On
Soft Turn On/Off
THD: <0.04%
S/N Ratio: >90dB
