atomic apx 15
salve
cerco le caratteristiche di questo sub qualcuno puo aiutarmi
http://www.extremeaudio.co.uk/product_pdf.php?id=427
Ecco i parametri..
queste le caratteristiche..
Dual or Quad Coil Configuration
Extreme SPL competition Woofer.
One of the highest efficiency Woofer in its class
3 seconds short burps up to 25,000Watts.
Custom impedance matching to your amplifiers.
EXTREME SPL competition woofer
High sensitivity, extreme efficient motor to ensure high SPL possible
Rigid Die cast aluminum basket
Organic long fiber non-pressed cone body for accurate tight bass
Highly damped Kevlar reinforced cone body
Extended neck joints on cone, coil and spider strengthen the integrity of moving structure for high power capacity
Triple layers foam surround increase the power capacity of woofer.
Compressed mounting ring gasket
Vented coil for extra heat dissipation
3 inch high temp aluminum voice coil
Extended, machined cut one piece back plate
Powerful 1 inch thick 90 oz high energy magnet
Over 2-1/2 inch long excursion motor structure
Reinforced resin impregnated polycotton spider extend the life span of the speaker from material fatigue and collapse.
Integrated heavy duty lead wire on spider prevent short circuit and melt down
Dome shape dust cap design
Low carbon front and back plate
Vented magnetic gap technology
Laser etched, machined and chromed back plate
Handle up to 25,000Watts in 3 second short burps
Work in progess.. Big Grin
Nn tanto portato da bassone vero?
(03-02-2013, 00:06 )love_low_bass Ha scritto: Nn tanto portato da bassone vero?
Non so, non conosco il sub in questione. Smile
Non molto.
Io ho l'apxx15, il top di gamma, usato, e rotto dopo infiniti test di ogni tipo.
Are there any hidden secrets or Easter eggs in the geometry dash lite version?
Potrebbe esserci un problema con l'amplificatore stesso. La bellezza di Snake Game risiede nella sua elegante semplicità
