NUOVO IMPIANTO SU GRANDE PUNTO
CIAO A TUTTI , VOGLIO RIFARE COMPLETAMENTE L' IMPIANTO ALLA MIA GRANDE PUNTO ,
UN AMICO LO FAREBBE TUTTO CORAL .... COSI :
ANTERIORE : MK 165
Nuovo Sistema di altoparlanti 2 vie con midwoofer da 165mm
2-way stereo loudspeaker kit
240 watt max power / 120 watt nominal power,
50 ÷ 20K hertz frequency range, 92 dB (1 m / 2.83 V) sensitivity,
165 mm woofer diameter, mica-polypropylene injection cone,
26 mm voice coil, kapton former,
49 mm neodymium tweeter, treated silk dome,
26 mm voice coil, aluminium former,
2-way crossover filter, 3100 hertz crossover frequency, 6/12 dB/oct
3-step changeable tweeter level,
hi-frequency electronic power control
POSTERIORE : MK 130
Nuovo kit 2-way stereo loudspeaker
200 watt max power / 100 watt nominal power,
60 ÷ 20K hertz frequency range, 92 dB (1 m / 2.83 V) sensitivity,
130 mm woofer diameter, mica-polypropylene injection cone,
treated silk dome,
3-step changeable tweeter level, hi-frequency electronic power control
  consigli impianto claudiog 1 11 21-09-2023, 18:58
  Audison AP690 o Focal ISU690 per upgrade impianto di serie? Audiovonb 14 49 17-07-2022, 00:07
  Impianto Golf 7 ITA-Ale10 1 348 15-07-2022, 08:22
  Consiglio impianto Entry-level Deviljack 4 832 18-02-2022, 19:07
  impianto pegeout 107 loop585 9 1.135 02-06-2021, 03:22
