SPLW-12 oppure 3XL-15D ??
ciao a tutti!!! xfavore potreste dirnmi quale sub di questi due e meglio x spl???
SPLW-12
• 2200 watts power handling
• 1100 watts RMS
• 340 oz. magnet
• 4” BASV/Kapton hybrid 18 AWG voice coil
• FS 33.5(Hz)
• Vas 0.8 cu.ft.
• Qes: 0.34 • Qms: 5.668
• Qts: 0.32• Xmax: 0.47”
• SPL90 dB
• Sealed box: N/A
• Ported box: 2.4 cu. ft.
• Tuning: 40 Hz
• Port size: 4” (dia) x 16.75” (length)
• # of ports: 2
• Mounting Depth:7.25”
oppure
3XL-15D
• Power Handling Capacity (Peak) : 2000W
• Power Handling Capacity (RMS) : 1000W
• Nominal Impedancel Big Grinual 1 ohm
• Voice Coil Size : 3"
• Frequency Response : 24Hz - 400Hz
• Sensitivity : 93 dB/W/M
• Motor Structure : 542 oz
• Mounting Depth : 9.2"
ciaooo e grazie!!!
  Hertz ES 300 oppure Coral hds 812 mioro87 8 1.973 20-05-2010, 19:12
  SUB con 1 BOBINA 4ohm oppure 2 BOBINE 2 o 8ohm? Dani88 1 1.141 19-05-2006, 22:03
