Pareri su questi
Cosa ne pensate di questi due amplificatori per biamplificare un coral monza mk165.
Lighting Audio Strike S300.2
Strike 2-channel amplifier.
75x2 @ 4 ohms.
150x2 @ 2 ohms.
300x1 @ 4 ohms.
18dB variable x-over from 50Hz-250Hz.
Phase Switch.
0dB to +12dB Bass EQ.
Remote Level Control.
POWERcell option.
SONY XM2100GTX 2-channel car amplifier
100 watts RMS x 2 at 4 ohms (125 watts RMS x 2 at 2 ohms)
250 watts RMS x 1 at 4 ohms (4-ohm stable in bridged mode)
low-pass crossover (50-300 Hz, 12 dB/octave)
variable bass boost (0-10 dB at 40 Hz)
MOSFET power supply and output stages
Tri-way capable (Tri-Way crossover required)
CEA-2006 compliant
preamp- and speaker-level inputs
preamp outputs
gold-plated connectors
fuse rating: 25A x 2
Inviato dal mio SM-N7505 utilizzando Tapatalk
  Pareri/impressioni Sony XM C6000 Maverix 119 20.712 17-11-2022, 03:40
  pareri phase linear 0.6 kw andry 54 33.346 23-10-2022, 02:23
  pareri audiosolution calliope's art biancho 39 8.563 26-05-2021, 00:52
  pareri ampli andry 16 3.587 25-05-2021, 18:28
  Sound_digital 400.4 pareri SGRASS 0 486 19-04-2019, 16:11
