infinity... ne vale la pena???
ciao gente... qualcuno ha mai sentito suonare l'infinity REF611a???
riporto le caratteristiche....
456 Watts RMS x 1 channel at 4 ohms and ¡Ü1% THD + N
Dynamic Bass Optimization. (DBO) Circuit
RCA low-level inputs
Remote bass level control optional (ref100rc)
657 Watts RMS x 1 channel at 2 ohms, 14.4V supply and ¡Ü1% THD + N
One pair full-range preamp outputs
12dB Built-in variable HP/LP electronic crossover
Signal-to-Noise Ratio 70dBA (ref. 1 watt into 4 ohms)
Dynamic Power 1314 watts at 2 ohms
Effective Damping Factor 6.336 at 4 ohms
Frequency Response 17Hz - 251Hz (-3dB)
Maximum input signal 6V
Maximum sensitivity 250mV
Output regulation 0,179dB at 4 ohms
Minimum Input Level 381mm x 305mm x 68mm (L x W x H)
che ne dite???
  Casse e sub infinity Griso 2 7.207 26-05-2021, 00:40
  Qunato vale un f2-450 Montese 3 801 23-05-2021, 20:45
  Hertz, Infinity o Coral? hamradio 4 3.873 29-09-2012, 02:50
  Quale amplificatore per FA: Infinity Kappa65.5cs FP: Impact HS 6530+Hertz HT25 gjmen 5 2.083 28-05-2012, 02:16
  Infinity Kappa Perfect 6.1 Spacecarletto 1 947 05-05-2007, 05:17
