box x subwoofer herz es 300
ho bisogno di saper il tipo d box.d mm 260.xmax mm 9.re ohm 3,1.fs hz 30.le mh@1khz 3,17.le mh@10khz 1,11.vas lit 73,50.Mms gr 156,0.cms mm/n 0,19.bl t-m 12,80. qts 0,5. qes 0,55.qms 7,60.spl(1m/2,83v) 91,6 questo sono tt i parametri del subwoofer herz es 300 700watt max 350 rms
  Problema botto subwoofer LaPanteraNera 3 211 01-04-2025, 17:29
  Subwoofer hertz hx380d Danielec83 2 71 05-08-2022, 07:36
  Subwoofer raccordato Cav84Ra 3 85 26-07-2022, 03:06
  Subwoofer ES300 Hertz Energy CaptainKid 2 80 21-07-2022, 02:32
  Subwoofer SPL 7.18 db burn 46cm romeosamuele 0 225 25-03-2022, 07:24
