NUOVO IMPIANTO SU GRANDE PUNTO
CIAO A TUTTI , VOGLIO RIFARE COMPLETAMENTE L' IMPIANTO ALLA MIA GRANDE PUNTO ,
UN AMICO LO FAREBBE TUTTO CORAL .... COSI :
ANTERIORE : MK 165
Nuovo Sistema di altoparlanti 2 vie con midwoofer da 165mm
2-way stereo loudspeaker kit
240 watt max power / 120 watt nominal power,
50 ÷ 20K hertz frequency range, 92 dB (1 m / 2.83 V) sensitivity,
165 mm woofer diameter, mica-polypropylene injection cone,
26 mm voice coil, kapton former,
49 mm neodymium tweeter, treated silk dome,
26 mm voice coil, aluminium former,
2-way crossover filter, 3100 hertz crossover frequency, 6/12 dB/oct
3-step changeable tweeter level,
hi-frequency electronic power control
POSTERIORE : MK 130
Nuovo kit 2-way stereo loudspeaker
200 watt max power / 100 watt nominal power,
60 ÷ 20K hertz frequency range, 92 dB (1 m / 2.83 V) sensitivity,
130 mm woofer diameter, mica-polypropylene injection cone,
treated silk dome,
3-step changeable tweeter level, hi-frequency electronic power control
  Consiglio impianto Entry-level Deviljack 7 1.890 , 18:47
Music Impianto Audio a soffitto completo "smart" per casa nuova MarS 6 2 939 03-12-2025, 03:21
  CONSIGLIO PER UN IMPIANTO CAR AUDIO SOUND QUALITY franco 82 2 2.137 21-07-2025, 17:31
  consigli impianto claudiog 2 368 11-06-2025, 13:58
  Primo Impianto (Qualità no casino) carmeloc94 71 28.146 19-03-2025, 06:34
