26-08-2014, 17:31
(Questo messaggio è stato modificato l'ultima volta il: 27-08-2014, 02:51 da hyper.)
Salve,ho acquistato usati su ebay due subwoofer coral evo 262,ora vorrei realizzare la cassa reflex.
I dati dei subwoofer sono questi:
nominal impedance (Zn): 4 + 4 ohm
nominal power (Pn): 250 watt
max power (Pm): 500 watt
sensitivity (2.83 V/1 m): 90 dB
frequency range (BW): 30÷300 Hz
resonance frequency (Fs): 32 Hz
voice coil diameter: 50 mm
cone material: cellulose pulp
surround material: butyl rubber
basket material: stamped steel
magnet material: ferrite
mechanical Q factor (Qms): 6.49
electrical Q factor (Qes): 0.6 (*)
total Q factor (Qts): 0.55 (*)
moving mass (Mms): 95.8 g
compliance (Cms): 0.26 mm/N
equivalent volume (Vas): 43 litres
force factor (BxL): 10 N/A (*)
voice coil resistance (Re): 3.2 + 3.2 ohm
voice coil inductance (Le): 1.4 (*) mH
emission diameter (D): 210 mm
linear excursion (Xmax): ± 9.5 mm
(*) parametri misurati con le bobine in parallelo.
Quanti litri bisogna fare la cassa? Non ho problemi di spazio e vorrei accordarli sotto i 40 hertz,come reflex unico tubo o doppio tubo?
PIONEER DEH-P5900MP
FA:CORAL MONZA - AUDISON VR 206
ALPINE SPG-69C3 - SORGENTE
SUB: DOPPIO CORAL EVO 262 + ROCKFORD FOSGATE punch 250x2
