PARERE ACQUISTO AUTORADIO DVD
SE L'OGGETTO SOTTO COSTASSE 130 EURO CON GSRSNZIA 1 ANNO, MA COMPRATO SU EBAY DA 1 NEGOZIO CHE NE DITE????'
[Immagine: 200612311347_autoradio_dvd_divx_1.jpg]
CARATTERISTICHE E FUNZIONI:
1) DVD / DVD-R / MP3 / VCD / CD / CD-R / CD-RW / DIVX (MPEG4) compatible
2) High performance FM / AM receiver (FM: 87.5 - 108MHz,
AM: 522 - 1,620KHz)
3) Flip down detachable faceplate
4) RDS function
5) 45 x 4 high power output
6) LCD display
7) Front panel AUX IN (read MP3)
8) DC 12V supply
9) Last Memory Function (LMF)
10) Preset EQ (Pop / Rock / Classic)
11) Multi-function IR remote control
12) Dolby AC-3 / DTS decoder, 4.1 Channel Audio output
13) Operating temperature range: -20 ~ +80°C
14) Anti-shock housing, advanced ESP (DVD:3s, CD:12s, MP3:110s
15) Comes with full function remote control
16) Connect to a CD/DVD Changer
DVD Deck Section:
4 Channel RCA Preamp Output (DVD)
Preset EQ(POP/Rock/Classic)
Discs Played : DVD, DVD-R, VCD 1.0/1.1/2.0/3.0, MP3 , CD , CD-R , CD-RW,Picture-CD
Video System : AUTO/ PAL/ NTSC
Mounting Angle : 0 to +/- 30 Degree
Video Section:
2 Channel RCA Preamp Output (VCD)
Video System : 4:3 Letter Box and 4:3 Pan Scan
Video Output Level : 1.0V p-p 75 ohms
Horizontal Resolution : 500
Audio Section:
2 Channel RCA Preamp Output (MP3)
Maximum Output Level : 2Vrms(+/-3DB)
Frequency Response : 20 to 20 KHZ
Signal-to-Noise Ratio : 85DB
Separation : 80DB
AM/FM Tuner Section:
Frequency Range: 522-1620(Europe/China),530-1710(U.S.A.)
IF Range : 450MHZ
Usable Sensitivity(-20DB) : 25DB
Tuner Range : 87.5-108(Europe/China), 530-1710(U.S.A.)
Usable Sensitivity (-30DB) : 15DB
Signal-to-Noise Ratio : 60DB
Stereo Separation : 30DB(1KHZ)
Frequency Response : 30~15000HZ
Accessori: - Telecomando IR; - Cavo di ingresso A/V; - Manuale;
  Acquisto autoradio Dar 1 0 05-06-2022, 13:41
  Autoradio frt63oop 0 386 24-12-2021, 20:51
  AIUTO ACQUISTO AUTORADIO!! speedforever 10 2.342 26-05-2021, 11:34
  Acquisto per impianto fp.semeraro 9 1.946 26-05-2021, 07:03
  consiglio acquisto autoradio OPEL ASTRA 98 jaydj 12 3.608 26-05-2021, 06:25
